A couple days ago I sold the CHT steam gauge along with others, so now I am flying around without accurate #'s, but I know how to interpret the erroneous #'s enough to keep me out of trouble, but obviously this is a short term solution. Other's have suggested is a programming error, the unit was setup incorrectly at the factory. Is there a way I can deal with problem without having to re-install a whole different unit? Or should I just continue to do the math, divide by 4 whatever number I see, to get the correct value? That's a joke, I hope
Wrong CHT temps
tominidaho
Wrong CHT temps
I am consistently showing (EIS 2000) CHT's of 800 plus degrees, while my old steam gauge, re-installed until yesterday, shows the usual 180 to 230 degrees. It seems to show high by about a factor of 4. I have triple checked my install, everything is correct. I am using the probes supplied by GRT for the Rotax 912S. These probes are grounded to the same direct ground that the EIS power supply is grounded to (not the airframe).
Re: Wrong CHT temps
Is the Rotax set up different? For Lycomings the CHT probes are not grounded, both wires come back to the EIS
tominidaho
Re: Wrong CHT temps
Bob,
Halfway through reading your response, I realized where I had gone wrong, and went out to the hangar to confirm it. I had somehow construed the wiring directions so that I had the white wire from the sensor going to ground, not back to the EIS. Powering everything up confirmed the now correct reading: CHT of 74 degrees, just like the EGT, while parked in the hangar. My bad! If we ever meet I owe you your favorite beverage, seriously, thanks
Next question, when am I getting my Mini?? Ha ha.
