I saw this combination at Sun N Fun and was really impressed.  Never got the chance to
ask if this is available as a package from GRT.
							echoUAT and GPS 2020 availability
Gene Mohr
SFC(R) US Army
S17 Twin Lakes Airport
						SFC(R) US Army
Re: echoUAT and GPS 2020 availability
We are working on making a package and mounting them together.
GRT_Jeff,
Any idea when these will be available? I would love to save the $100 on the GPS.
Gene Mohr
SFC(R) US Army
						SFC(R) US Army
I have the Echo that I bought at Sun n Fun and want to connect the traffic output to my Hx.  Right now I have Zaon connected to pin 20 on DU2 which is a serial input.  Can I connect the Echo to the same pin and does it use the same baud?  I purchased the Hx in 2010 and I will be disconnecting the Zaon.
Dan
Dan
You can use the same pin as long as the output on the HX port doesn't require a low baud rate.  The rate is shared for the input and output pins on the same port.  The recommended rate for ADS-B In and the echoUAT is 115200.  The minimum for ADS-B In is generally 38400.
Another vote for the bundle!
I have a friend at our airport that just installed this, waiting for feedback but the setup looks very promising and attractive in price and easy upgrade/install.
