Charts and USB sticks?
jpfli
Contact:
Post by jpfli »
With a dual HXr setup ......
My assumption is a single stick will supply data to both screens
Where is the best place to plug in the map memory stick?
1) USB Hub
2) Rear of EFIS
3) Panel connector
A behind the panel connection can't be bumped; a panel connection can be reattached in flight should it come loose.
[Also posted on VAF Glass Cockpit forum]
330drvr
Re: Charts and USB sticks?
Post by 330drvr »
Seattle Avionics says you need a separate flash drive for each display device.
RV-7A
