Configure Bar Graphs on PFD
I just loaded software version 8i on my Sport HS EFIS. A new feature is
"Make bar graphs in the bottom engine strip configurable"
It appears the CHT and EGT graphs are not as wide as previously and the existing fuel qty, oil temp & oil press graphs are quite wide. I went thru the General Setup, PFD, Engine Info System, Engine Limits, Moving Map and Graphical Engine Display menus without seeing a way to configure the bottom engine strip. I would like to add volts and amps to the display. Any idea where to look?
Re: Configure Bar Graphs on PFD
In the SET MENU, Graphical Engine Display section, scroll down to find Split Bar Graph 1 through 6 after the regular Bar Graph A and Bar Graph B settings. If all 6 of them are Off, you get the defaults that match the previous version.
